Latest Posts
Showing topics posted in for the last 365 days.
- Past hour
Hi. I have a nice 2007 Grande which is still in good nick, except for the drivers floor mat. Normally it wouldn't be a problem to replace the floor mat but because it has the word CAMRY embroidered into the floor mat, I would like to replace it with the same again. I'm feeling reasonably confident that a Toyota dealership would just laugh at a request for another factory one so my question is, is it even still possible to locate an embroidered floor mat for my 17 year old car? If so, where? Or is there a business that will replicate the original?
- Yesterday
Very nice mate, do you have the lovels part number? Are the front sport low and the rear super low?
Yes mine is October 2023. It arrived late February Early March to the docks in Brisbane. I have a friend who has been told that hers will be in the next shipment but is only on the production line now. So future stock should be 2024 ! ?
- Last week
a surge fried the controller
if it runs a cable find a friend that can push on it with a pole and see if that works first,sounds like a fork problem but atleast doin what I said u will find out
Not every Estima is fitted with the 2GR-FE and U660e drivetrain. This is where you have to take care that information on the internet is applicable to your specific vehicle.
Parviz replied to MichaelG's topic in Other Toyota Models
I rent a 2023 model in US just few days ago it’s beauty and real good on fuel much nicer to drive compare to Honda Odyssey which I own one 2022 model make me wonder why Toyota AUS won’t bring the Sienna hybrid to Australia instead we get bulky ugly looking Granvia with diesel engine 🤔🤔!! -
I have a Yaris and had a similar issue. I just submitted a similar query to GPT. The response was to go into settings, view paired devices, select the device to remove, and confirm the removal. It helped me; I couldn't find the answer on the internet, but I found it there.
Welcome to the forum Kiril, this is the place to linger and learn for sure. There are many great minds and people here who will always help with advise or expertise. Enjoy KAA
Anyone know of someone that can make or sell a JZX100 Chaser Triple gauge pillar pod? I need one for 60mm, willing to pay top dollar similar to the one attached
Hey guys, Looking to buy a triple gauge pod for the A-pillar of my Chaser, 60mm, Or if someone knows where I can get one made I am happy to pay top dollar, Thanks,
If you're actually asking a question, you need to provide a little more detail...
You'll see quite a few Japanese companies which have similar names to other ones due to the syllabic Japanese language (words are made up of syllables rather than distinct letters, so there are only so many combinations), or because they are named after their founding (and many people/places have similar names, also due to the syllabic nature). Both Aisin and Aisan get the first half of their name from the Aichi Prefecture (a Japanese province) they started in, it gets a bit complicated after that (Japanese is a strange language, you can have individual syllables that are pronounced one way but when combined with another are pronounced differently, so the San part of Aisan comes from Mie Prefecture (both san and mi are related to the number three). Aisin comes from when Aichi Kogyo (Aichi Industries) merged with Shinkawa Kogyo (Shinkawa Industries) to form Aisin Seiki (Aisin Standard, or something similar). Another good example is that a lot of Toyotas will have Mitsuboshi (Three Stars) accessory belts, not to be confused with Mitsubishi (Three Diamonds)
Having just discovered this group and having made a significant reply to a Land Cruiser question from a member, I'm wondering why there is no specific discussion forum for Land Cruisers, given their popularity. This is now particularly relevant given the unavailability of the missing (from the web) LCOOL forum (Land Cruiser Owners On Line). This was a great forum with a mountain of very valuable information regarding Land Cruisers, but it has disappeared. Does anyone know of other sites that cater for LC owners? I know of the Facebook group Landcruiser Owners Group Australia but find it useless and too hard to navigate. I am not a Facebook fan! Kind regards Geoff
Why is my car misfiring when cold? Suspect a loose connection/weak power supply to either the fuel injector or the ignition coil when temps are cold. Use noid light or test light to check the signal from engine computer to injector and to the coil when misfire is present. If both are firing/working correctly, inspect for cylinder damage/low compression.20 Feb 2021 When weather is cold it starts and misses for a minute or 2 JustAnswer https://www.justanswer.com › Car Questions Engine hunting and surging at idle is usually caused by a fuel delivery, air leak, or governor system problem. Cleaning/overhauling the carburettor, adjustment of the governor, and/or changing the air filer may be required. Why does my engine's RPM seem to fluctuate (runs rough)? Vanguard® Commercial Power https://www.vanguardpower.com › faqs › browse › wh...
The synchro is worn out bud.
I treated my Prado 120 to a 2-channel (front and rear) dashcam with parking mode. How to hard wire the dashcam to enable parking mode? Do you have any installation instructions for the Prado 120?
Does anyone know my Toyota Hilux vzn167 utes 2004 indircators on my dash is going haywire? When I indicate both dash lights flash & when I turn the headlights on & press the brake pedal the dash indicator lights & exterior lights flash dimly.
Hi,Im wondering what I need to do to swap out a 3Y to a 22R in a 86 hilux I know I need to change the bellhousing,engine mounts unless theres some sort of kit from 3Y mount to a 22R) but Im not too sure about gearbox compatability like spline,mounting holes etc
Steve, I have purchased a second hand pump assembly from a wrecker (with 3 months warranty) for $250. I hope it doesn't have the terminal showing signs of heat. It should arrive next week. I think I will be able to get the pump out through the inspection hole. I will keep you posted. Kind regards Geoff
Whats with those small links?
BTW forgot to mention that there is no shake in the steering wheel. The 'shudder', really hard to describe but almost like brakes on and off. Cannot identify front or rear or both. Got me totally miffed.
Hi, I'm Magazi in NSW I'm a new member
Sparky600 replied to Maga's topic in New Members Introductions
G’day and Welcome Maga I’m new here so Sorry can’t help but thought I’d say 👋 -
Hi everyone, new to this forum - refugee from LCOOL. Having read some of the replies, to the best of my knowledge there is no such thing as a minor remap. Toyota in their wisdom have the software in the ECU such that it cannot be downloaded, modified and reloaded. It has to be a complete reload, either stock or modified. All you fellows disconnecting the battery is a good and simple way to try and reset everything but similar results can be achieved by simply disconnecting the ECU. That's the big plug in the firewall passenger side. Meanwhile I may need to start a new topic for the following issues I am experiencing: Had a minor shudder when applying the brakes. Also was somewhat intermittent. Having over 100k on the clock a lot which were done towing a big van, I thought I may have warped a disk. Checked them with a dial gauge but no useful info. Bit the bullet and replaced all 4 with new slotted rotors and pads from DBA. Huge difference in braking. However the shudder has return almost with a vengeance. Thought I fixed the problem when I disconnected the ECU for another unrelated issue. ECU is remapped, car went in limp mode and could not clear it with the scangauge. Problem not fixed and I am lost as to why this is happening. Plan on visiting Berima Diesel later on this year to have the injectors checked and I'll get them to look at the brakes if I still haven't figured it out. Any suggestions would be welcomed. Thank you
