Disregard the below, car is now 3S-GTE powered, 5S-GTE was a fail for the moment, read on for more info.
When i first bought it nearly 4 years ago, it was a basically stock ST184, with only wheels, a cat back exhaust, and a Pioneer CD player.
The first thing I did when i got it home, was strip the stereo from my wrecked SA63 Celica and put it in, aside from that stereo and a pod filter, it basically stayed the same right up until mid 2009... When, after looking around on CelicaTech and 6gc.net, i got the idea in my head that I could turbo it.
Now, the most common way of turbo-ing an ST184 is to simply swap a 3S-GTE from a GT4 celica, MR2, etc in to the car... but I felt like being different.
I decided I would try what a lot of guys in the USA have done... turbo the 5S-FE that is in the car already... Below is a basic list of the parts i used to do this;
Parts used;
CT26 Turbo
3SGTE Exhaust Manifold
3SGTE Dump Pipe
GT4 Celica exhaust flange (to make an exhaust to fit)
K&N GT4 Pod filter
2in Aluminium intercooler piping kit + Silicone Joiners
No brand 26x6x3 intercooler
HKS SSQV Blow off Valve
Greddy Emanage Blue
Blitz MSTT turbo timer
Denso 360cc high impedance injectors.
Walbro 255lph fuel pump
VDO Oil T-piece
heat shielded rubber coolant/water lines
Speco Boost Gauge
Zeitronix WBO2 Controller
Bosch WBO2 Sensor
Zeitronix LCD Display (Boost, EGT, AFR, etc)
The car is currently running and has a pretty safe/basic street tune in it... but after burning out the clutch I decided I need more power;
So here is STAGE II
-Full rebuild (got bearings, rings, gasket kit)
-3S-GE Head - purchased
-New Front Suspension
-New Brakes - Bendix Ultimate Pads, purchased
-New Clutch - Exedy HD, ordered
Parts used;
I have done a few exterior modifications to the car since I purchased it;
Exterior
GT4 Front Bar
GT4 Fog Lights
GT4 Bonnet
de-spoilered
flat-black rattle can paint job
17x7 ROH Boost-R wheels
Below are some pictures of the car how it is right now;
Sign In
Register
MultiQuote
