Help
Search
Members
Calendar
Full Version:
Deck and door light not working after wiring the sub, HELP!
Toyota Owners Club - Australia
Toyota Models
Echo / Yaris
ARTA8SIMS
Sep 29 2008, 07:38 PM
My Deck and door light not working after wiring the sub. All I know is I spark the battery when Im disconnecting it, what could blown up?
X-Power
Sep 30 2008, 01:01 AM
Green 15amp fuess in side car fuess box, or in engine bay they should be another 15amp one too, wat sort of car is it?
ARTA8SIMS
Oct 1 2008, 06:32 PM
Don't worry, I found it. Thanks for that. I've read the service manual and it said is a "dome" fuse.
diviCe
Dec 12 2008, 08:28 AM
QUOTE (ARTA8SIMS @ Oct 1 2008, 07:32 PM)
Hi, where abouts is the dome fuse located? as our car has the same problem... thanks in advance.
the_random_hero
Feb 7 2009, 04:07 PM
QUOTE (diviCe @ Dec 12 2008, 08:28 AM)
Fusebox, probably under the dash or in the drivers kick panel.
Eargunk
Feb 7 2009, 08:04 PM
jsut wonder how did the spark happen, cause usually i remove the negative terminal and leave the positive on and put a rubber cap over the negative.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here
Invision Power Board © 2001-2010
Invision Power Services, Inc.
