QUOTE (11TWO @ Feb 17 2009, 09:52 AM)
QUOTE (comutech @ Feb 17 2009, 11:24 PM)
Thanks guys I thought it could have been an overheating tranny but what would cause this to suddenly happen the car is about 4 years old and I run the hell out of it and yes I know it’s an auto but it still runs great, I change the oil ever 6000K the only thing I need to do is change the plugs and recommendation on what I should use?
M on the dash means M for Manual mode is my guess. If the M is flashing then I assume that it's telling you to shift into the next gear???
Maybe you need to get your transmission serviced...
The M is to indicate that you have changed for auto mode to manual only it does not indicate when to shift, if you don’t shift in time it will just hit the rev guard.
When you say service what are we talking about, what is done in a tranny service?
more detailed...
http://www.fluidrive.com.au/An Automatic Transmission service should, at minimum, include the following –
1. Old fluid must be drained out.
2. The transmission oil pan should be removed and cleaned.
3. The specialist will inspect the old oil and residue in the transmission oil pan for signs of metal filings or debris from the clutches which will indicate any internal damage or impending transmission problems.
4. The filter should be removed and cleaned. (Some transmissions have a "throw-away" filter in which case a new filter should be fitted).
5. The bands and controls (where applicable) must be checked and adjusted.
6. The filter must be refitted.
7. The transmission oil pan must be refitted using a new gasket.
8. The transmission must be filled with new transmission fluid.
9. The transmission should be checked for fluid leaks.
10. The car should be road tested to check the transmission operation.
