QUOTE (croatiaboi @ Nov 6 2009, 07:12 PM)
HI guys
Im looking at a set of wheels im just not sure whether the offset would fit the aurion without spacers etc.
The wheels are 19 x 8.5 with +38 offset.
This all depends on whether you plan to lower your car or not. If you do lower it, you run a higher change of it scrubbing if you don't stick close to the factory +45mm offset. If you don't lower it, you should be fine. One thread of interest:
Need a little advice on wheelsAnd a link to help you plan things:
Wheel Offset CalculatorAlso as well, with a +38mm offset, a spacer is only going to make the problem worse.
