QUOTE(-JC- @ Apr 9 2006, 06:24 AM) [snapback]79739[/snapback]
QUOTE(leasaunce @ Apr 8 2006, 11:35 PM) [snapback]79730[/snapback]
also........how do you put them on??? clips? or self-adhesive?
Brake and clutch pedal slide on with a little encouragement.
Foot rest needs 4 starter holes drilled in it, the screw the plate to the footrest.
I'm doing the go pedal today, but apparently the actual pedal arm has to be removed to if it.
Good luck with your instructions, mine are in japanese.
same as mine instructions in Japanase. luckily pictures say a thousand words!
to me the easiet way was to remove the whole gas arm and take out the lil pin and then is all good.
Sorry jason i already got myself a pair
for under 80 bucks too!
