White smoke on start up
Hi coopersmummy - mine is doing exactly what you described... What did it then out to be and what fixed it for you - cheers
coopersmummy was Last Active Jun 13 2011 10:49 AM, odds are you won't get a reply.
To remove sludge the quickest way, on a straight 4/6. Drain oil and keep . remove rocker covers and sump, steam clean refit covers. Refill with old oil. Start run for 5 minutes or so drain and fill with new oil...
Used to do this working for a import shop...
Cheap oil is not the issue, lack of oil changes is the issue. I used to use cheap oil $15.95 stuff... on my ae92 corolla changed the oil every 5k . Swapped the engine out at 485,000 pull the rocker cover off inside was like new...
      Toyota Corolla 2012 zre152 transmission issue
    2. 46
      Lowering a Corolla ZRE
    3. 3
    4. 1
    5. 3
    6. 23
      Transmission U660e
    7. 3
    8. 4
    9. 7
