Toyota camry sportivo 2007 fuel filter replacement need some info
sportivo2007
My car is due for a fuel filter change so i went to Toyota and purchased the filter, i told him i wanted the complete unit including the bottom filler ,but they never give you the right part unless you go twice loll
does anyone know what the part number is for the bottom filter that connects the the fuel pump ?
see the pictures below
16m66id.jpgOLD
u92l5.jpgNEW
Part number for the fuel filter is 77024-8Y002
Thanks for the info ,i went to Toyota today and that's what they also told me ,its $677 :wacko:
Toyota said it comes with the fuel pump ? that's a joke am not changing my fuel pump just for a small filter i just need the bottom filter strainer
anyone tried to clean it or do it another way ? there must be an alternative ?
Edited by sportivo2007
Andrew -am going to take out the filter tomorrow hopefully ,will take pictures of the bottom
firssecondlast - i went to super cheap yesterday they said there not sure if it does come with the filter ,unless i order it
i was watching on YouTube some people clean it , is that OK to do ?
OK so i went to super cheap and they want 200 for the pump ,so i just decided to give it a good clean with lots of decreaser,
it turns out you can remove the bottom filler which is weird that you cant buy it separate from Toyota
that is how dirty it was before cleaning
after cleaning it all the dirt came out
all ready to go in
the mess
My carmy is done 150,000 kms now ,that's what i thought too it is alot ,and i been only using shell and BP fuel
i cleaned it with super cheap decreaser spray it on leave it for 5 min and then rub it with your fingers ,and do it over again till there is no more dirt ,then i washed it with hot water, and just dry it with a blow dryer
      Fuel Tank transfer
      Kakadu GVM
    3. 4
      Caravan towing
    4. 2
      Hi, I'm Magazi in NSW I'm a new member
      How to reset service interval light
    7. 5
      Tyres
    8. 7
      1998 Toyota Celica Pricing idea
    9. 54
      Rattle on engine start
    10. 5
      Tyres
