Aurion pull left, quick question
Hi all,
If I go out and buy SuperPro Poly Bushes SPF2904K and have them installed, this will eliminate my left pull issue right?. Car is an aurion sx6 2007.
Or do I need to have something checked/diagnosed before doing this?.
It should resolve the issue of the car pulling left with just the installation of the part you've listed. The part is designed to adjust the caster of the suspension set up. Bear in mind that small adjustments can be done on the factory suspension set up that can help change the geometry which leads to the car tracking straight
It will depend upon the level of experience and expertise that suspension specialists have. All it is an extensive wheel alignment which are never carried out at dealerships and tyre shops, because at tyre shops and dealerships, they put your car on the machine which only measures toe (the direction at which the wheel is pointing) and that's all they adjust. I would go to a suspension specialist to ask them if they are able to adjust the camber and caster settings, simply by loosening the bolts of the strut tower and moving the strut back and forth to get in within specifcation. Some suspension specialists will be able to do this, some won't.
The wheel alignment from these guys will cost you a bit, but will most likely offset the amount you have to fork out for the caster bushes. Have a look out for suspensio specialists around you and get their opinion.
Note: I had it done to my car during the summer after it had the 'pulling to the left' symptom, and it resolved the problem and the car still tracks straight today, all for $100.
Edited by Noodle Boy
