PLZ HELP PEGASUS WHITE ADVICE
Marni
Hi all,
So I need some help, my 86 was in an accident recently and I was wondering if any of you have had successful panel resprays in the "Pegasus White" (37J)
I've heard that because its a pearl colour the whole car will need to be resprayed so all the panels match, does this sound right to anyone?
The car has been damaged on the passengers side front, bonnet, quarter panel and obviously reservoir and anything else that was hiding under there.
I take a lot of pride in the car and want to make sure that if it requires a full respray, in order for it to all match and look right that the insurance company will need to do it.
What have you guys seen or recommend I do?
Had some issues a while back with a Gold Camry Sportivo paint job after an rear end shunt accident, looked great until you put your polorized sunnies on in full sun then you could see where they had sprayed. They thought I was crazy till I pointed out the sprry lines that could not be seen with the naked eye. Made them do it again!
Funny you should say that.
My Aunty had the same thing with her gold sportivo
Three times it's been sprayed and still not right
      Hi, I'm Magazi in NSW I'm a new member
      Muffler change for zr6
    4. 26
    5. 7
      which engine oil
      G’day from NSW
    7. 3
      Landcruiser 200 GPS
    9. 1
      Aurion "wobble"
