hilux questions 2009
Bulldogs195461
just a couple of little questions,ive just bought a hilux workmate 2.7 only 50,000ks.when you start it up in the morning its a little noisey,but after 5 minutes warming up its perfect is this fairly normal,and also i thing the clutch is a little hard to push in,any suggestions,its got 3 months warranty from the dealer so im just after any info from others,these things ,may be normal.other than that,absolutly very happy with this ute,cheers john
For the noise on start up it might be the injectors. You should get that confirmed while still in warranty as they aren't cheap.
For the clutch get the fluid in it checked. Do you have another HiLux to compare it too as it might be fine, might just be harder than what your used to??
Ok, will try to get injectors checked with them as I said only last five minutes or to the corner and then fine, probably when warm, and I agree the clutch could just be me, I'm very car illiterate lol, that's why I'm here.
  • 4 weeks later...
      Oil Pipe Leak
    4. 54
      Oil Pipe Leak
      Thinking to get Yaris, what to look out for?
      Swapping hiace motors
      How much oil does my engine take?
      Brake issues with 2024 Corolla Cross Hybrid
      Catalystic converter below threshold bank 1
    10. 1
