need factory carburetor set for my 99' hilux
hani jamal
hello everyone
firstly I am happy to be here in this fantastic forum
so let's get to the main subject
I have 1999 toyota hilux and the old carburetor is dead and need to be change
but the problem is / the carburetor has been repaired many times and missed the original wiring set
So now I bought new one and need to install it in my car So
i need your help please
I want the factory instillation set for carburetor please
thank you in advance
Sorry, I don't understand what you need. If it's a carb as such. default is PROB 2 turns out from light close on idle mixture, butterfly just opening . Once it fires, you can tune it much better. Don't panic if it revs hi, you need it to start and run to adjust more correctly. Default delivery settings are prob close to what you need, with adjustment for local altitude and weather. Carbs are assembled to a standard setting, as described in the service manual, and should at least start out of the box.
      Landcruiser 200 GPS
      Aurion "wobble"
    3. 54
      Oil Pipe Leak
    6. 54
      Oil Pipe Leak
      Thinking to get Yaris, what to look out for?
      Swapping hiace motors
      How much oil does my engine take?
