Ln106 Turbo installation help Thanks
marsheen
Hey all so i have a stock ln106 2.8 litre 3l engine just wondering if i have to decompress the engine a bit before i install a turbo and what would the max psi i should run on a stock engine thanks.
{MO decomp not necessary, 7psi enough and do not exceed 5L performance by more than 10% -- you will need boost compensator to do that propperly My reasons are that the motor cannot dissipate the extra heat well, and if you overdo it, you'll crack the head or overheat the motor. be very careful how hard and how long you drive it hard. you will need digital temp gauges for water and exhaust. If it's power you want, buy a nissan with their bigger motors, otherwise put up with the modest but usually sufficient OEM motor. The L series is at the end of development, unless an alloy head becomes available, and that's unlikely. The Chinese have one for the 2.2L L motor with side cam and rockers, but I've no proof how good they are nor it they'll fit the later motors.
    2. 2
    3. 23
      Transmission U660e
    4. 2
    5. 4
    6. 7
    7. 1
      New Guy....
      Gauge Pillar JZX100
      JZX100 CHASER A Pillar gauge pod
