Standard height of a 1999 dual cab hilux (3litre diesel)
maccaslux
Gday,
want to check the height of my car against stock.
Please if you know the measurement from the middle of the hub to underside of tire arch (body) it would be greatly appreciated, cheers
Brad
Roof Height: 6th generation
4WD Regular Cab/Extended Cab: 1,775 mm (69.9 in)
4WD Crew Cab: 1,795 mm (70.7 in)
2WD Regular Cab: 1,600 mm (63.0 in)/1,650 mm (65.0 in)
2WD Extended & Crew Cab:1,695 mm (66.7 in)
Thanks Manxman, have you any idea if this is from the bottom of the rim or from the deck up?
ide assume they wouldnt measure from the floor since tires sag etc would all be different, but 1.8m would be from the floor.
no worries, well mines around 1800mm give or take 20mm hard to gauge, and thats with bigger tires, so guess i still have standard hieght suspension and the torsion bars havnt been wound up
      Oil Pipe Leak
    4. 54
      Oil Pipe Leak
      Thinking to get Yaris, what to look out for?
      Swapping hiace motors
      How much oil does my engine take?
      Brake issues with 2024 Corolla Cross Hybrid
      Catalystic converter below threshold bank 1
    10. 1
