1997 5S-FE CAMRY OIL LEAK
975s-fe
theres an oil leak somewhere behind the engine and i can not see where its coming from , any ideas it keeps running off onto my cat and pisses smoke everywhere , but its not losing much oil tbh its just i need to find it for rwc
didnt even no it had em hahaha
SXV20 Camry 5SFE heads have 3 blanking plugs to fill in the ends of the camshaft line-bores - 2 "half-moon" plugs on the ends of the head in line with the exhaust camshaft, and one full blanking cap on the passenger-end of the head inline with the intake camshaft (where the distributor fits on the SXV10/Celica 5SFEs). They are all common leaking points if they aren't re-sealed properly when the cam cover gasket is changed.
Had another look seems it could very well be the o-ring on the dizzy lol typical i shouldve replaced it when i did the internal dizzy shaft seal and bearing -_-
lol so far 2k spent on this peice of #### and its coming close to getting a duckin match and a petrol soaked rag i put a new thermostat in it and its god dam faulty, i swear i am going to lose it with this car soon and burn it to the ground after ive taken it out bush and stomped it till it dies
      Brake issues
    2. 1
      Brake issues
    3. 1
      Hi, I'm Magazi in NSW I'm a new member
    4. 2
      Muffler change for zr6
    5. 2
    6. 26
    7. 7
      which engine oil
      G’day from NSW
    9. 3
