Engine Swap
MrRob
I'm considering doing an engine swap with the TRD model. ( I know both engines are the same ).
Apart from the ecu, is there anything else need to complete the swap. I'm a little noob when it comes to engine swaps so any help will be appreciated.
Thanks in advanced.
As long as you get everything attached to the engine, you should have everything plus the ECU. A brake upgrade will also be required for legality reasons.
Awesome thanks. Seems simple enough. Already have TRD brakes on the car too so thats one less thing to worry about.
      Oil Pipe Leak
    2. 0
    3. 0
    4. 54
      Oil Pipe Leak
      Thinking to get Yaris, what to look out for?
    6. 0
      Swapping hiace motors
    7. 0
      How much oil does my engine take?
      Brake issues with 2024 Corolla Cross Hybrid
      Catalystic converter below threshold bank 1
    10. 1
