Posted (edited)
Hi!
My Toyota Avensis have a mini-size spare wheel and I am happy of this, because for me this is the best solution.
Nowadays there are four possible solutions when a tyre get punctured:
1) full-size spare wheel:
this is the classical solution but, for the life of the car, you have less space in the trunk and, above all, the car weights more, so the performances are inferior and the fuel consumption is thinly higher. In my opinion this is a money throw away solution, because a regular tyre and a regular rim are wasted for the life of the car.
2) "fix and go" kit:
this is the solution preferred on the luxury sport cars. It is a kit composed by a little air compressor and a can of tyre repairing foam. This solution weights very few and the space used is the lowest, but there is the big disadvantage that if the tyre is ripped and not punctured this kit is useless.
3) run flat tyres:
they allow you to reach the next tyre shop, also with zero pressure, but they are very expensive and often after a puncture they are to throw away. In case of ripping they are useless.
4) mini-size spare wheel:
this solution, in comparison with full-size spare wheel, allows you to have more space in the trunk and the car weights less, with all the relating advantages.
Alberto.
Edited by Alberto Michelatti
      Turboed Corolla Overbuilt?
    2. 3
    3. 3
    4. 0
    5. 6
    6. 18
    7. 5
      Tow bar
    9. 3
    10. 0
