Head unit clock and dash clock show different times - is this normal? (2020 Camry)
I have the same problem and it drives me mad. Did you get a fix for it? Larry -
Corolla Ascent Sport.: Model ZRE182R.C
My first post. I have just purchased a 2015 Corolla Ascent Sport and the alloy wheel paint has started to fade and is back to the primer in places. Where can I find the paint colour code for the wheels? I can't find it in the Owner's Manual or on the vehicle's usual stickers. -
Just signed up.
I have just purchased a 2015 Corolla Ascent Sport as a 2nd car. After driving it home from Brisbane it may become my "1st. car". Model : 2ZR-FAE E with 70Ks. on the clock. I may need some advice /tips from time to time. Alan. -
2019 door sill rust
I have a 2020 sr I bought new done bugger all 4 wheel driving all ways garaged under the plastic cover on the drivers side door the paint is bubbling and rust coming through still under warranty and Toyota will not fix it I have a 28 year old Commodore with no rust I'm so angry -
Jump starting a Corolla Cross Hybrid Atmos
Does anyone have advice on how to jump start a Corolla Cross Hybrid Atmos using a portable Jump Starter? Ie: a safe location to connect the negative clamp? (photos ect) The car manual instructions are to connect the positive clamp to the jump start post within the fuse box and connect the negative cable clamp to a bolt on the engine block which is approx. 1metre to left of the fuse box. The issue I have with portable jump starters is, the cable/clamp lengths are very short. To date I have spoken to the local Toyota dealer/service for advice but they did not provide me with any confidence for an alternative negative ground connection. -
Just signed up
Hi I have recently purchased a 23 Rogue, the third Hilux l have owned .l am in north west Victoria. -
1HDFTE into a 1HZJ76 troopy?? Anyone??
I was just wondering if anyone's ever dropped a 1HD FTE into a 1HZJ76 Troopy? I am considering this as a project and am grateful for any tips or suggestions. -
Suspension
looks like no replies for last couple of years.. I am thinking the same thing for my Estima 2008 (same model), which i have replaced all the suspension (adjustable coilover) myself, when I bought the car to lift the height to max, as it was too low. But the suspension that I purchased was from Japan and the max was still lowerer than the standard suspension. There are various coilovers in the market but hard to find the standard suspension with standard springs. I believe it is doable.. I will update when i find the right parts. -
What tyres will fit
Have a look at this URL https://tiresize.com/comparison/ https://www.redbook.com.au/cars/details/2015-toyota-hilux-sr-hi-rider-auto-4x2-double-cab/SPOT-ITM-425943?Cr=8 Tyre specification is shown as 265/65/R17. There should be sticker/plackard showing vehicle specifications and usually placed within the door opening near the lock. -
Diff and transfer case ratios
Hey all would love a hand with this I’m needing the ratios of the rear diff and transfer case for a 1999 105 series, the gearbox is a a442. My cruiser is fitted with a transmission controller an I’ve had some dramas with it lately I’m going thru a double checking all the ratios and details that have been put into it to confirm there right.
