C-ONE FRONT PYRO BALL UPPER MOUNT SET
you add enough spacers so the top spring hat clears the pillowmount in the installed position with whatever camber you intend to run.
With no spacers and the hat flush against the pillowmount you run into problems.
I installed the spacer between the upper pillowball mount and the upper spring seat and the problem that I was having with the metallic "chong" noise when the wheels were moving towards either "full left" or "full right" lock has been rectified.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
