what the???
hey yea did kinda notice the lack of something extra on that funnel... well if your still willing to do it then good luck!
Might wanna keep this point in mind
The Intake Funnel Does not Have Any Hole For The Sensor And You Have To Custom Made if You Need It
that looks exactly like flexible flue. the type we use on gas heaters. its readily available at plumbing suppliers and comes in 75mm,100mm and 125mm diameters. the length is normally 3 meters which you can cut to size. I don't know how well the air would travel though cos it has a ribbed interior wall which would cause a great deal of turbulence thus slowing down the air velocity. Rigid smooth walled cai would be the way to go.
nothing a stanley knife and electric tape cant fix .... hahahahahahaha .... actually who needs a maf anyway .... u'll b fine 2 run without 1 ...... hahahahahahaha
lawl
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
