d3fo's Corolla II Turbo
d3fo
Hi All,
I am a newb to TOC and thought I might upload some info and pics about my import Corolla...
It's a 1986 Corolla II Turbo edition
Current modifications include...
Engine:
Rebuilt 3E-TE 12 valve EFI Turbo
HKS Fuel Pressue Regulator
Aftermarket Oversize Injectors
High Pressure Fuel Pump
Reground Camshaft
Ross Forged Pistons
Garret GT28 Ball Bearing Turbo
Custom Manifold
Custom Turbo Dump
Huge Front Mount Intercooler
UniFilter Pod
2.5" Exhaust
Turbosmart Boost Controller
GFB BOV
Heavy Duty Clutch
Suspesion:
TRD Strut Brace
Lowered on standard Coil-Overs w/ King Springs
Monroe Gas Shocks
Upgraded Front Ventilated Rotors
Rolling Stock:
17" Dual 5 Spoke Mags
205x40x17 Rubber
Currently running 10-12 pounds until new ECU is fitted...
That's it for now, cheers for looking! :rolleyes:
-d3fo.
Cool.
Well, how does it go?? :ninja:
Weighing only around 850-900kg as you would imagine it goes quite fast and breaks traction very easily... :blink: thx, Hexx.
It's still only running 10-12pound, but the engine has been built to take upto 18-20pnd... just waiting a decent ecu to be fitted before I wind up the bleed valve.
Thanks for the comments guys!!
  • 1 year later...
Well, some 18 months later we have some progress...
Full rebuild, new rings/bairings, custom turbo manifold, dump, IC piping, Plenum and throttle body.
Piping, Plenum & Throttlebody...
Turbo manifold...
Fresh hd clutch....
Will keep you posted..
Thx for looking!
  • 1 year later...
Hi D3fo's
Just a quick question as to what company you bought you rebuild kit from Australia or overseas. I am in the process of starting a rebuild on an 1988 model Corolla 2 Turbo
I am finding it hard to locate a rebuild kit. Any help would be fantastic.
Turbo manifold...
Fresh hd clutch....
Thx for looking!
Howdy mate, I beleive toyota is still able to provide rings, barings and gaskets. We didn't need to get a kit so-to-speak as majority of the engine is now modified and bottom end was fresh when we pulled it down. Best bet would be to give Ferris a call @ Quattromotive, these guys have been doing the rebuild, check www.quattromotive.com.au for contact details.
Good luck and keep us posted.
-d3fo
Hi D3fo's
Turbo manifold...
Fresh hd clutch....
Thx for looking!
i know the corolla and the corolla 2 are different but have you finished yours yet and if so how much power did you make i know when it comes to corolla's you cant beat bill's stivo but hey im not to far off how bout you
Hey robie,
The engine build is finished, but the tuning has just begun. So, roughly about another 2-3 weeks until rwc and all bugs sorted.
You know there has been alot of speculation on what we should expect out of this motor from alot of differnet people but at the end of the day the dyno sheet will tell the story ( which I will post here ), you can make your own guess in the mean time... also have to keep in mind car dry weight is only 890kg I beleive.
-d3fo.
Hi people,
Good to see other EL31 fans exist.
I have 8 of these little bricks in my collection and have wrecked at least another 5 or so.
I have an 88 gp that im currently using as a daily that runs 13 psi (love the torque curve).
I haven't had any time to do anything with them in a while but in the not too distant
future i will be focusing some time to play with them.
I will be parting some of them out but will only relinquish parts to dedicated enthusiasts.
Anyway guys keep up the good work.
Hi people,
Cheers Sonic76, Good to meet another el31 fan and even better that you have spares!
I will be chasing some door cards and a clean dash if you have one around, let me know.
To all.... she's nearly on the road. Will post pics when registered.
Cheers,
d3fo.
  • 9 months later...
Alas, it's time to go.... 4 years in the shop, over 25k spent and now a young one on the way, so the toys have to go.
This littel el31 now has literally the most worked/modified 3e-te engine on the planet. It's being delivered next week and will promptly be listed on ebay & autotrader for around $6k mark.
I will post pics of all the new running gear, the good, the bad, etc. as soon as it's on my drive way.
Thanks for reading and if anyone might be interested, please please please reply, becuase I would really like to see this mental unit go to a good home.
-d3fo.
  • 9 months later...
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
