hey every one
ive got a 03 rolla ascent ive beeeen thinking for long while now bout the suprcharger for my baby any one done it yet?
and if so howz it going? and if so how does the superharged rolla go up gainst the spivos?
you have to do some internal work to the motor and lower the compression to be able to use the supercharger, not just a simple bolt on procedure ;)
Do a search mate you certainly are not the first to want this info.
The TRD Supercharger is out of production so your only hope is to find a used one. Your other option is the Blitz Supercharger kit for 1ZZ-FE (Toyota Spacio, Toyota Wish) which is listed as 398,000Y without the optional intercooler setup, but you will need a different piggyback ECU if your vehicle is manual. More info on the Blitz kit can be found at toyotaownersclub.com in my signature.
Currently DuGong is the only member with a supercharged 1ZZ-FE, his car is automatic and uses the TRD kit.
I know the 2zz kits have been discontinued, so I would assume the 1zz kits have gone the same way. So better be quick if you want one brand new.
Posted (edited)
http://users.tpg.com.au/adsl0uxv/1zzfze.jpg
The TRD charger makes the same power as a mildly modified sportivo, only with a hell of a lot more torque from LOW in the rev range and a very linear power curve, no dips or bumps. It's like driving a corolla with a V6 in it.
You can accelerate in top gear when cruising with ease. The sportivo is still revving to get to lift while the 1zzfze is already gone in the distance. If you want a 1ZZ TRD charger you will have to scour US ebay to find one.
Edit: IMO the intercooled Blitz kit would do a lot better, intake charge temps are what kill the power with the TRD charger.
Edited by rollamods
That's why the Blitz is such an attractive option... however the intercooler is optional, I think an extra 300,000Y!
i know for sure that the kit for celica is discontinued so im guessing it is the same for the 2zz and 1zz corolla.. i have just bought one for the 1zz but there are still a few of each in stock so if you want one you better hurry!
Posted (edited)
how much did it cost ya angelo??
as tayles has already said 398,000 Y
would that make it a 1ZZ-FZE??
Edited by $ANGELO$
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
