Which aftermarket HID for Aurion?
Hyo
I need some help for my HID homework.
Thinking about getting one from the eBay, but which one?
I found Bosch one, but not very sure whether they are genuine or not (I couldn't get it linked. Generation VII, 191 dollars).
Would you recommend one for me?
Thanks a lot,
Edited by Hyo
Thanks a lot,
This is a OEM genuine one :P but it only accepts D2S bulbs
The only site i know that sells rebased genuine ballasts is xenondepot - btw they are expensive..
http://www.xenondepot.com/
just buy any brand, doesnt really matters. The headlight on aurion is designed for HID, so there isnt much(or should i say "no") glare.
Should only pay around $150-$180
I don't agree with that^ :idea:
The HID headlight has different lens and projectors. Therefore putting a HID bulb inside a halogen projector = glare...
Just because it is projector headlights does not mean a HID should fit in there.. (but then a lot of ppl do!! annoys ppl on the road!!)
+1
maybe i m lucky when choosing then..
i m just talking about case for Aurion, not other cars like camry
05, which i know the glare is just scary..
well certain cars do have more glare than others - yours seem to be on the better side (but you can still see some glare spots above the cutoff point)
and also the hot spots..
Just thinking logically, a halogen bulb were designed to fit in your headlight projector- and now you put in a rebased HID bulb, the optics of it is different so obviously its not used as it is intended....but there's nothing stopping you :)
Just FYI, This is a real HID
I also saw the bosch HID on ebay but then didnt know if it was legit or not so i didn't end up buying it.
Because usually german made HID would cost you 300+ so dont know why that one is so cheap.
I ended up buying a Kit called "Alpha HID"
i bought some MTEC 4750K bulbs that i have no longer use for since i got HID now
so if anyone wants to grab them off me for some $
just msg me or something =) the package has been opened just to see if it fits on the car, but hasnt been used.
Edited by ZZR88
I finally got the 4300K MTEC hid kit. :rolleyes:
I'm know that aftermarket HID is illegal but couldn't resist the 'brightness!'
I think it has a little bit of glare and hot spot. So thinking about lowering the angle..
Anyway, it looks good!
congrats
any pics?? from inside and outside the car?
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
