07 Corolla RPM
Hi all,
For everyone who has a 07 corolla, just wanna ask what are your usually RPM when driving? mine seems to be around 2500 when i pedal it, and sometimes up to 3000 when going up hill. Its automatic and is this normal?
I've been in my friend's car (honda jazz), the gear change on that car is around less then 2000rpm. So just wondering what all you others have?
Your rev range is quite normal for the Corolla. Some of the other small cars are different, for example my old's have a Getz and that car drives best around 2k rpm, cruising on the flat you can often shift at 1500 odd rpm. There isn't much point shifting higher in such a car anyway :P
The Jazz motor/box must be setup very similarly - for 'efficiency'.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
