My 2zz N/A Project
I am officially entering the 2zz N/A horsepower race I certainly own a Japanese market (JDM) Toyota Runx/Allex and looking to get all i can out of it. Below is a list of my parts that are being installed to the car
Initial setup will be:
Engine-
TRD high compression pistons 13.1
Ported exhaust manifold
Injen cool air intake
Piper Cams stage 2
Fidanza flywheel
Special coated bearings
Circuitworx Oil Pump Gears
C-one Final Drive 4.7
TRD LSD
TRD Short Shifter
ARP Head Studs
ARP Flywheel bolts
ARP Main Bearing Bolts
ARP Connecting Rod Bolts
Stainless Steel Valves
MWR Valve Springs
TRD Clutch Kit
Port & Polish Head
TRD Tremosat
Aqua Mist Kit (Water Injection)
Oil Cooler
AEM Underdrive Pulley Kit
MWR Moroso Oil Pan
Crower Billet Connecting Rods
Interior Mods:
Oil Pressure Gauge
Oil Temp Gauge
Water Temp Gauge
ECU:
FC Datalogit Software
Apexi Power Fc
Suspension:
Cusco Front Lower Stress Bar
D2 Suspension
Brakes:
Wilwood Calipers
Steel Braided Brake Lines
Hawk Street Pads
Misc:
GReddy Oil Catch Can
TRD Front Strut Brace
Apexi Turbo Timer
Edited by Most Wanted
lookin for a little more somewhere round 200+ at de crank :rolleyes: car should be very aggressive though
has anyone got mods like these on the 2zz? would have to be a very rough estimate because you wouldn't really know unless you did it.. but sound about right i guess??
TRD Final Drive 4.7
Do you mean Kaaz or C-One?
As for the pistons you might have to make sure that the bores are within spec to fit the TRD pistons.
Otherwise good luck and have fun!
sorry made a mistake final drive is C-one
and as for the pistons they are a straight fit
Do you have someone familiar with tuning a Power Fc on a 2ZZ? Cause it is not a simple plug and play. Every car is different so you cannot simply use a base map off another car. As for what you are doing my guess at power would be roughly 135-145kw at the wheels depending on how good of a tuner you can get to set it up.
Yes Air con and Temp gauge is an issue as is a consistent idle. Cause Hitman doesn't care about idle does he Northy/ Xoom!!LOL
nothing wrong with my idle now though :P :P :P :P :P
my guess would be that you would be looking at 150kw mark at the wheels ..... and it will have to be a happy rev'er as well ;) ;) ;) to take advantage of that power
do keep us updated.
We've got one stroked out to 2L in the garage ready to go into the racecar. We're running MoTec ECU.
Good to see some serious N/A mods on a road car!
TRD Final Drive 4.7
Kaaz don't make a final drive, only a short ratio gear set.
ECU:
Apexi Power Fc
Only Power FC??
You might consider installing a GReddy V-manage ECU to optimize all mods and tune every single cylinder individually :spiteful:
an Apexi Power FC is a full replacement after market ECU ..... to the best of my knowledge the V-manage is only a piggy back thus requiring the stock ECU to be present and also will on work on ur valve timing .... nothing else ..... (http://www.jdm-option.com/eng/parts/07_01/vmanage.html ...... interesting that it also does dual VVti for those new corolla owners) so the V-manage will actually not provide anything anywhere near better than a power FC.
How about the Haltech or Xede interceptors.
very tunable units.
They work on Vtecs so why not give it a go on the 2zz
because no one wants to front the cash to be the r&d guinea pig pete .... simple as that ..... plus there isnt a lot of people who have worked their cars to the point where that sort of expense is actually required.
The power FC to a certain degree is plug and play .... however im also looking keenly at the hydra EMS as they seem to have come out with a corolla specific 2zz ecu and i wonder if that has more potential than a pfc as its only marginally more expensive.
very tunable units.
That is true hey.
Mmmm Hydra EMS sounds like Mr research has been at it again!! :spiteful:
I guess your biggest issue will be finding the time to play around with the hydra
what fuel are you hoping to use with the 13.1 comp pistons?
I was waiting for that. This was mentioned in that TRD 2ZZ upgrade kit thread if I recall.
Maybe Most Wanted lives in a place where 100 octane fuel is readily available, as he has a JDM RunX
I'm still under the belief that the goal posts have been set very high here. From what I have seen with those mods listed, you would be looking at less than 170ps atw. Especially seeing how you are using the pfc, the engine I saw with a motec made 130kw atw, and the motec is much better as it allows you to control in closed loop.
If you want to stay NA and be powerful, I would stroke it to 1933cc. Makes closer to 150kw atw, but the torque difference is massive.
Just my 2c
Just a little note.
Be careful with the selection of a standalone ECU for the 2ZZ-GE.
The Haltech, for example, can't handle the variable cam control. It can only switch from full retarded to full advanced cam timing not full control in between.
Not many can. The Motec M400/600/800 can.
Neil
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
