Water leak in 91 Paseo
Paseo91
Hi all
I have picked up a 91 Paseo today but it seems to leak coolant from somewhere near the drivers side of the engine. I can only see it dripping off the corner of the sump but where would it likely be coming from? The water pump?
Regards
EDIT: I just had a friend look at the location of the water pump and he thinks the engine mount may have to come out to replace it (?!)
Edited by Paseo91
The water was leaking out the little hole in the housing of the water pump which a mechanic told me indicated the seal was gone again. It was a new water pump but the engine hadn't been run for 2 years so it must have gone hard (the seal). I got the water pump replaced and it doesn't leak water anymore.
Edited by Paseo91
I put in coolant and assumed it would be hold 5 litres of coolant but only 3 litres was needed. Amazing, I've never seen an engine with only 3L of coolant. The extra strength coolant wont hurt it will it?
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
