will these wheels fit?
pod66
im looking at buying some wheels from a 1990 camry, will they fit my 87 camry
dunno, but you can measure the stud pattern, call toyota and ask or failing that take your existing spare wheel down to the place where you intend to get the '90 wheels from and compare by retro fitting or side by side comparison.
  • 5 weeks later...
should be the 4x120 PCD and offset is the same as the earlier Celicas
No such Toyota stud pattern as 4x120, RWD Celicas are 4x114.3, most FWD Celicas are 5x100 (as are all the early Camrys), all the way up to ST204, not sure what the ZZT231 uses. Newer Camrys use 5x114.3, which basically every Toyota car bigger than a Yaris uses (including the new Corolla)
    3. 21
    4. 21
    6. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    9. 7
      Help - Blowing white smoke
