Personal Lights
Razor
Hi
just got the camry and noticed that the personal lights don't work.
I checked the bulbs and they look like that the filament is still intact.
tried measuring voltage and its zero.
dome light works... do they share the same fuse?
Thanks in advance
Hi
Thanks in advance
Check the light around the key ive put neons in the foot wells and i have them run off the key light so that there is a delay and gives a pretty cool effect being that i dont have an ultima and havnt realy looked in 1 so this is really just a gues and saying have a look at that as they run off a different circuit (well i presume due to the delay) if thats not the case then i could only assume that they have there own fuse...i dont think that makes sence anyway give that a crack if worst comes to worst try and trace the wiring back it might be a long and painfull proscess but it will deffenatly give you an answer. Thats about all i can suggest for now. I just remembered something so i hadto edit the post but i had trouble with the lights behind my a/c controls 1 half kept flicking in and out and i found out where the factory split was to the 2 different lights the connection was shotty so i chopped and resoldered it with a decent connection and never had trouble since. being that the interior lights now that i think of it it would make sence to keep them on the same lines off the doors they may be the same problem i experianced. good luck with it.
Edited by Bangers88
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
