i just went out to get a better pic... its now raining, but i got one :P
Evo
  • Replies 131
  • Created
  • Last Reply
Top Posters In This Topic
Here,
it looks to be the same... and i am willing to try it :D
Evo
Clearly, mine are a bit worn in, so its worth a try ;)
Evo
Just remember evan that you are comparing the washer on top. You can't really see the bushings haha
Also isn't it a b**** to take photos of those bits?
well, i dont really have much to lose...
im gonna do it :D
and yeah, it is a bitch trying to take the photo lol :P
Evo
Alright,
well guys, after much deliberation, i have found out that YES the bearing kit for the 2zz fits on the 1zz...
BUT and this is a big BUT, the bushing for the Vertical one is outrageously large, and i had to put it back in... which was a serious mission.
But shifting 'feels' alot smoother :D in order for the Vertical one to be done, i would have to get a much larger bearing if that's possible.
So if you want better shifting, only half the kit works for the 1zz's and that's just changing the HORIZONTAL bushing.
Evo
I guess thats better than nothing. How much bigger do you need to get?
About 10mm bigger... if not more... just guessing
Evo
ahh good on you for trying Evan...
if you can shoot me some exact measurements i will see what i have here.
damn... i have to pull it apart again, but ok, i will have to do it during lunch time and then i will have a more accurate measurement
Evo
Hey Andy, it looks to be about 2.6cm Outer diameter, and the internal diameter is the same as the bearings from the 2zz kit.
Yes, that's what i measured, the lip on the bushing to hold it in place brings it up to 3cm, so the lip is only 2mm on each side, so take 4mm from that is 2.6cm
OD = 2.6cm
Evo
I just had to try it, and now the gears slide in a whole lot better :D
just need to wait and see if Andy can get me the right sized bearing ;)
Evo
it was good for a while, now.. sometimes its impossible to get into 3rd gear :(
I know what you mean. I just thought maybe that was because I had a crappy gearbox from the previous owner. When shifting from 2nd to 3rd it feels very rough
well not sure if i am pleased to say... but its got nothing to do with my shifter kits....
BKS its definitly not your kit. I would still recommend this upgrade to people
Shifting will definately feel more postive. So will the defects. If you hadn't felt it before, doesn't mean you wouldn't forever. This mod is meant to remove the free play from your shifter. Not fix sucky gear changes ......
Maybe its time to consider clutch replacement ............. :huh:
In comparison, my shifting feels sucky all of the time at almost every gear, especially the lower ones. But none the less, I would refuse to go back to rubber ones compare to what I have now.
I wouldn't recommend it... :o
I WOULD PROMOTE IT!!! :yahoo: :yahoo: excellent job Andy :D
Evo
  • 2 months later...
  • 1 year later...
just thought i'd share this rather than making a new thread.
part numbers have slightly changed as well as the price... $7.50ea
how come you got 6 of them... where else are you using them
      Anyone had this Issue
    2. 0
      Camroad
    3. 326
    4. 326
      Camry high rise spoiler
    6. 0
      24 inch Toyota light bar
    7. 0
      Hi Folks
    8. 3
      Aircon problem need help
    9. 1
      Throwing a P0047 OBD Code
    10. 4
      Has anyone had issues re-installing intake camshaft 5SFE
