Posted (edited)
Hey
im a long time reader short time poster. :P . just wondering if anyone had changed their pedals. I drive an ascent :o and wondered which ones you would recommend and what dimension or measurments i need to know before swaping.. and anything else i need to know before i do a swap
thanx in advance C-rolla :)
Edited by C-rolla
stoke ones are good for driving
the aftermarket stuff is bad when went
if your going to get a set of pedals get the most expensive ones you can afford
due to the excessive wear, the cheapo ones break, and when you drive bear feet, the sharp metal bits cut you,
The toyota ones are pretty good, fit perfectly and you get new screws, and a foot rest bit usually other brands are only the 3 pedals
Posted (edited)
For ease of install I would look at the Sportivo peddles (if they fit on the ascent)
But at $120 a set?????? its a bit steep :blink:
Personally I went for the "Sparco' option. They cost $85 AUD but the install was alot more involved than the sportivo option.
As the stock peddle on the accelerator is too norrow and made of plastic. So the arm had to be modified with a new metal plate moulded to the shape of the peddle and then welded onto the arm.
Also the clutch plate had to be modified slightly.
But agin this is a personal thing :D
P.S check out my garage for the pics ;)
Edited by Danthuyer
thanx everybody for there replies.. i think im just gonna go for the sportivo pedals..
gonna go down to toyota today :)
thanx
C-rolla :ph34r:
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
