SPORTIVO CLUTCH ADJUSTMENT
Azza
i'm getting my clutch adjusted in a couple of weeks and have been warned that the clutch will sit up alot higher
is it that bad, i am hoping that a smooth shift especially between first and second will make up for the new clutch position
ull get used to it after few days
u wont even remember how it used to feel ;)
Well after i had mine readjusted, it did sit alot higher and the clutch enagged quicker However, i think it went back to its original condidion and i cant get smooth changes in high revs anymore. Back to mr toyota i think :(
Any updates from you, Blue_Stivo or ZEEROLLA?? :P
Not yet mate, i'm still waiting for a Service Manager to contact me.. its been a while and i might not wait. I'm also thinking of getting a new clutch and TOM's flywheel fitted soon bcos i can't be bothered lobbying around with Toyota anymore, plus i've already got a TOM's flywheel lying around.
Anyway if anything comes up soon i will probably still consider letting Toyota have another look. Will kep this thread updated.
Zee
Just a quik question, I am currently in "discussion" with the service manager from where I bought my Sportivo on the subject of clucth adjastment and also a whistle the car produces. They are adamant that these hydralic clutches can not be adjusted in anyway. If there is an adjustment - via the master cylinder - then will this be a one off or will there be a continual need to adjust - cause I am just sick of it all!.
Also , mine is afflicted with the whistle - reviewing the content on this site I understand that to fix - just adjust the brakes - but the dealer tells me that these brakes are not adjustable in a any way. Anywone have any further info on this.
Eck
Zee
Eck
WTF
Zee
Eck
WTF
Double WTF!
Take it to another dealership, I would assume that these guys have NFI!
The clutches ARE adjustable.
Azza
Had mine done at Lexus Indro. My pedal sits higher indeed! It takes a little getting used to but it definitely improves the jamming problem at low and high revs. Improves the notchiness problem (but does not remove it). When I queried Lexus about it - my mechanics name was Val (I think) he indicated that the height of the pedal was a direct result of following the Technical News Flash to the letter.
SPH
  • 5 weeks later...
Any updates on this issue???
took the car in - the dealer refused to touch the clutch and said it was acceptable - I asked if the clutch mechansim was at least checked to spec - he advised no - reiterated that the the clutches are self adjusting and nothing could be done. Basically palmed me off.
I note that that on the sportivo that I test drove (had about 13km on the clock) the gear changes were almost featherlight, friction point was were you expect it to be, really nice to drive and is why I bought the car. My car is quite tight and 3rd gear is notchy, friction point started mid way. The dealer said it is a (1100km) new car and that it should soften up with time.
I've given up on that dealer, next service - not sure whether to take it to Chatswood or Sydney City - I will ask them to fix.
I wish I had better news!
Take it to Sydney City Toyota Camperdown. Their customer service is top notch compared to the original dealer that I bought my car from. They did my clutch adjustment without me even asking...
Just to remind some of you that if the clutch adjustment is done properly, it should sit up much higher than normal. If that's not the case for you, it means they didn't do the adjustment according to the field fix.
This is what I was told by the tech from Toyota HQ who took care of my concerns and enquiries.
Hey all!!!
Wed Wocket went in for it's 10K service today, and had the Clutch Adjustment done...
QUESTION - Who else has had this done, and did you end up with the clutch pedal up around you ears....???
I have noticed that the clutch pedal itself actually sits alot higher than it used to (where it used to be fairly level with the brake and accellerator) and now the clutch needs to travel a longer distance to hit the pressure point...
It's always like that. I'm used to that clutch position anyway (from my Escort group N track car). Give it some time and you'll get used to it. It's much better for shifting quicker (less crunching), as it compresses the flywheel more this way. Closer to the floor = less compression and more chance of crunching shifts at high rpm.
Let the quicker shifts begin Azza :D
Hey all!!!
Dude, that post was Feb 2005
Edited by Azza
i went to nunawading toyota today i ask if i could re-adjust the clutch so it will let me into 2nd gear in high rev, and the guy asked me "how high rev u talking about" i told him 6000-8000 and he was shocked and he reokon it should not be in such high rev and change gear, he told me to let the rpm drop to 5000rpm and change gear!!!!!but i pretty much told him to shut up and just book me in , because i dont have warranty any more so i will pay for it anyway, so yeah i booked for next thursday, so u guys sure by re-adjust the clutch will improve the gear changes?? why they(dealers or toyota mechanics) all think the sportivo should not rev that high even though they know its built to rev high!!!! if i dont rev beyond 6000 at all why the hell i buy a sportivo!!!!
Edited by sportiyo
that's a standard response by Toyota <_< :angry: tell them not to treat you like an idiot and this ssue has been talked about ever since the Stivo came out and people are sick and tired of Toyota and hat you will be getting a Honda next time :P
Hey all!!!
I am sorry I did not realise that the post was Feb 2005
who gives a rat's a$$ if it was a feb posting - the stivo should hopefully live for a while - it is an ongoing issue so an opportunity should exist on this forum to discuss this issues or just old plain old jane topic going forward! :angry:
I said I was sorry :(
Oh wait...you're defending me aren't you?
Don't worry man, it was just 1 person having a go at you when you did the right thing.
IT'S ALWAYS BETTER TO BRING UP AN OLD DISCUSSION THEN START A NEW ONE!!!!
Well done, I commend you on that :)
You had valid points to raise
Γ— Β  Pasted as rich text. Β Β Paste as plain text instead
Β  Only 75 emoji are allowed.
Γ— Β  Your link has been automatically embedded. Β Β Display as a link instead
Γ— Β  Your previous content has been restored. Β Β Clear editor
Γ— Β  You cannot paste images directly. Upload or insert images from URL.
    5. 21
    6. 21
    8. 3
      Selling vintage 1996 hilux
Γ—
Γ—
