Lowering a Corolla ZRE
YBHVE4
the gap between tyre and guard is about 4 fingers for front but the ones at the back is about 3-4cm more. is tthat the same for everyone else? wat did u do bout it? if i lower my car by 3cm all round, its not gonna do anything to balance the front n rear is it?
if i lower the front by 2cm, back by 4cm, is it going to have negative effects on the car or tyres in the long run?
xfancier
Suppose the car should be lower not only looking to a gap between tire and a car, but the side skirt should go in same line as the ground, be parallel.
I've got -6 cm, but still the skirt not parallel with ground. Ford inf front of me is -5 cm, but it's parallel.
if u r doing 6cm drop all round, the side skirt and the ground are never going to be parallel.
you probably have to drop the rear by 2cm more... or lift the front by 2cm so that your car will sit level.
that's what i am hoping to do. i have a brand new corolla with stock suspension. the back of the car sits about 2-3cm higher than the front and it really bothers me a lot. the sight of the uneven gap is driving me nuts.
i called different stores, spoke to a number of different specialists and decided to have the rear lowered by 1 inch by using Eibach springs. hopefully the car will sit level after this tiny change. and hopefully by lowering the back only will not put my car at higher risks of mechanical problems.
By the looks of that pic the front is quite low. As with the ZZE's to get the car to sit level you put lows in the front and super lows in the rear. Cars sits level front to rear within 2-4mm.
  • 4 months later...
Anyone put coilovers in a ZRE yet?
I need info,prices and feedback please.. :) I need convincing that its not just vanity :D
edit: reason iam asking is cos i want front 10mm lower, or just go Lovells superlow and get good shocks when time comes.
DON'T DO IT MAN!....or are you just getting the car ready to the royal nasho run at the end of the month :o
lol coil overs
i called lovells today and their office is only down the road from me, i got quoted $330 for all four springs i got the part numbers aswell front:TFL-131 rear: TRL-132 apparently they are a 30-35mm drop, that is for the stage 1 kit which is just springs and the stage two kit is a bout 40-45mm didn't get a price on it though, hope that helps
Charlie
lol coil overs
Charlie
The lovells on their site are what iam after,which are
F - TFL-131 SL
R - TRL-132 SL
which iam guessing is the stage two(superlow) you mentioned,shouldnt be anymore should it?
Is that what your getting? :D
yea that's what im looking into, and they are the same price $330 for the SL stage 2 kit just need to find some1 to fit them otherwise any zre owners out there who want to give me a hand in putting them in it would help aswell
my mechanic got them for me. i think it costs 330 for you due to courier costs. my mech. went and picked mine up.
no courier cost for them their distrubution office is 5 mins from my place, and that's what tehy quoted me, o well i guess i'll just have to shop around again for the right price
and this is the part where you say, "i'll ask my mechanic if he could get two sets of superlows for my fellow Toyota enthusiasts " ;)
if he can sounds like a deal.....lol i wanna at least lower my car before the end of the month meet.... :D
  • 14 years later...
On 3/22/2009 at 7:51 PM, YBHVE4 said:
yeah mate...Lovell.
cheers
Very nice mate, do you have the lovels part number? Are the front sport low and the rear super low?
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
