Got My Tail Lights On
Here are some pics of my custom tail lights.
It really gives my car another look.
Really like it :rolleyes:
I'll show you a bit of the process.
Next step, lower my car.. B)
Unpacked
Stock tail lights
removed stock tail lights
Stock vs Custom
Cutting wires, plug didn't match
Stock vs Custom on the car
Couple of pics
Oh wow, can u pm me an guided instruction of how to change or wire those cabling?
as mine is a prefacelift rolla, but i have a pair of face lift tail light sitting on my garage but dont know how to change the plugs?
if u can, it will be great! :)
thanks
thanks
hey i've done this for my 03TIVO, if you look carefully at the plug, you can stick a small screw driver into the wires where the little clips are, you apply pressure and slide the wire out of the plugs then feed the wire and clip it into the new plug,
gday, just curious what does your grille look like? got allex on the back with the chrome bit on the hatch door.. im thinking the grill will be somewhat different to the runx then.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
