04 sportivo replace ecu without dealership coding it ?
Average Fuel consumption display
Is there any way to reset this? I know it resets when you refuel but is there a way to manually do it? I changed the front rotors and pads(DBA T2 - Recommend them so far) yesterday and it reset my L/100km. Is that due to the fuel level changing in the tank due to being jacked up? Thanks EDIT: Also to hijack the topic anybody aware of any decent weathershields? I can only find ebay specials which Im not sure of and the genuine ones I can only find for the front and id like a full set. -
Floor plan for 2018 H200 series Hiace single-sliding-door?
I'm looking at putting a plywood floor into my cargo space, but I can't find a floor plan anywhere. I want to cut holes in it to expose the tie-down points and spare-wheel release, so it'd save a lot of hassle if I could find a template and get the thing laser/water cut. Does anyone have a floor plan or know where I could find it? -
Lubricating u joint steering shaft?
Sealed joint, lube wont make any difference -
Greetings once again, I was wondering if I should lubricate this u joint under the steering wheel with white lithium grease in order to make my steering wheel feel lighter? (attached pic has the reference), I got curious from a recent post here in lieu of such, thankyou so much -
401
TURBO AURION - Beast Mode *Page 1 updated - Page 21 for Turbo*
I know this is a long shot but any chance you’re still active here mate? Loved the videos of the aurion you have and wanted to do a somewhat similar style with mine. If you wouldn’t mind let me know the best place to ask some questions mainly about where to resource some parts -
2023 parado wheel size
G'day all. I have just purchased a 2023 gxl parado with a 2inch lift. What I'm wondering is what's the maximum size tyre I can fit on it without causing scrubbing and also voiding the warranty. I won't be doing any serious off road with the vehicle just the occasional beach trip here and there. Cheers joe -
4
Aurion stalling randomly?
Possibly dirty Idle Air Controller. It may have carbon build up and not allowing air to be drawn in at idle. I know mechanics wouldn’t miss this . But just in case they may have overlooked. Otherwise I would get a code reader and see if there are any error codes that can point you in the right direction. -
How to diagnose central locking issue with Camry Sportivo 07
Basically check fuses with your multi meter and also swap over relays. Have a look this video. It might help..👍🏻 https://youtu.be/zCJw8x6XNCQ -
200 Series Land Cruiser has a ghost in the interior lights
Hi All I have a 200 Series Land Cruiser (2007) which is randomly switching on the interior lights while driving. Thinking is was as simple as a faulty door switch, we've isolated them one by one and it's still happening. Our next step is to look at the rear tailgate as the culprit. Does anybody have any info they could provide on how the light switches work for the tailgate as it appears to not be as simple as a push switch like the side doors. JB
