SPARK PLUG REMOVAL
roger t
Has anyone replaced the plugs on a 2005 Kluger. If so was the intake plenum removed as per the shop manual for the rear bank? To remove the plenum is straightforward but I worry that I may not be able to replace the 3 bolts for the plenum/engine steady brackets as the access is poor and blind. I do not think it is necessary to remove the steady brackets, just undo the top bolts and hope they line up when the plenum is replaced. I cannot see that the plugs can be replaced with the plenum in situ. I do not trust main dealers to this job.
Roger
Roger , unsure of exactly what the engine looks like but working on a V6 magna was a similar deal to what you have described and if your not overally confident yourself find a reputable mechanic that can show you his work and discuss your concerns rather than dealership servicing it , remeber service books etc.
    2. 0
      2013 Rav4
    3. 4
    4. 29
      toyota 700
    5. 4
    6. 1
      2018 Landcruiser 200 Sahara Heavy steering
    7. 0
      Always get a second opinion
    8. 29
      toyota 700
    9. 29
      toyota 700
