Parts and Labour Costs for A Major Job on Camry V6 Vienta
K8Canb
I am looking for some advice, please help
I need some idea about approximate cost of parts + labour the following items in 1995 Toyota Camry V6 Vienta VDV10 with 3VZFE motor, which has now clocked 210000 kms. I live in Canberra where the prices are ridiculously high. As I often visit Sydney, I could get the job done in Sydney. Please aslo suggest couple of places (dealer or private workshops) who do good work for a reasonable cost. I am looking for the following replacements:
Timing Belt
Idealer pully and associated bearings
Water Pump
Cam shaft, Oil pump and Crank shaft seals
Alternater/air conditioner drive belt
Spark plugs
Clean Injectors and replace their O-rings
Clean Air intake
Replace both valve cover gaskets
I will ask around and obtain quotes from few places in Canberra also.
ahhh yes the camry major service.
not sure where you would go in sydney. I just went to terry shields toyota and got the tbelt, sparks, leads and injector clean and o rings replaced. For the life of me, I cant remember the price, bout 1 tonne + from memory (so worth it, car ran like new)
With your shopping list of things to get looked at / changed, I'd be looking around $1500 for a good proper job.
Hope that helps.
FYI, I have an unused water pump in a box, pm me for details.
      2004 Hilux SR5
    2. 2
      1-Piece Brake Rotor?
    3. 0
      Standard suspension
    4. 2
    5. 2
    6. 2
      Toyota 2023 single cab tray alterations
    7. 1
      Toyota prado 2018 Rattling noise?
    8. 13
      What do you use
      Workshop manual
    10. 13
      What do you use
