caldina sounds funny
could be an exhaust leak, could be the car is misfiring, or running on less than 4cyl.
Check your exhaust system, plugs/plug leads, distributor, coil, injectors/cables, etc. also check timing advance/retard
I think you guys are right. I pulled off the heat shield and noticed.. theres a stud missing. Closet to the alternator....
The exhaust gasket feels flimsy... If you were to push down on it... it would pop back. Similar sound the the juice bottle lids... YOu know... When you have broken the seal..
Is this a serious issue? Can I drive around like this and cause no ill effects? sorry for the noob question. I am here to learn.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
