Hey guys ive had this question on my mind for a while. ive noticed a few people lowering their cars and theb reseting the rear springs, if one was to say lower the rear springs only would this be similar to restting the rears on a lowered set up?
why on earth would you want to do this?
That would look retarded. rear slammed and front still way up high. you want even stance.
guys are resetting their rears because they're current lowered springs like mine (king springs low) in the rear sits slight higher than the front. Which gives ur ride a forward 'dipped' stance. from side on view.. it looks uneven.. and the more you look at it.. the more you notice that big gap where ur whole fist can go through. i think im guna just go superlows on my rears. then i'll be happy.
The "dipped" stance comes like that from the factory.
Lowering just the rear would mean that your ride would be quite uncomfortable. Front will be soft and rear will be stiff. With superlows, the drop isnt even that much more lower. There's still a gap.
What I recommend is that you get a set of springs and reset the rears to desired height OR get a set of coilovers which requires a bit of saving.
If superlow rears drops it a further 20mm from what it is now, i'll be happy as larry. :lol:
arnt i supposed to be gettign your lows ;)?
i know a few people have opted to go lows on the front and super lows on the rear ...... i havent driven a setup that has had this done so cant comment on the effect it has on the handling front ....... personally i prefer that looking down / nose dive look but u knw each to their own
      Touchscreen unit for 2012 Aurion Sportivo zr6 cost
    2. 1
    3. 7
    4. 0
      New owner 2024 Prado questions
      Selling my 1972 Landcruiser FJ Pickup
    6. 0
      How to permanently turn-off lane assist
    7. 1
      Hiace 300 series 2019 V6 petrol- Spark Plug Replacement
