1990 Camry wont start the car wonts to kik over but fails could it be the fuel pump
It could be one of many things man...
By wont kick over do you mean it tries to turn over but makes a clicking sound, or it will just keep turning over with nothing happening?
If its the first one, check the solonoid, this is the most likely problem.
If its the second, it could be one of two things, fuel or spark. Check both systems.
If it won't turn over, nothing or just a clicking sound. Suggest 1. check battery terminals are clean and tight 2 check battery for charge ie could be flat or may be need new battery or reco: alternator . 3 starter motor might need replacing. Or if absolutely nothing, could be wiring. ignition switch, solenoid, etc.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
