2002 Avalon Leaking Sunroof
TheJackal
You will need to get it resealed.
Best thing to do is take it to a Sunroof dealer or even places like Windscreen Obrien and they should be able to put a sealant in for you.
Theres a few places in Sydney that i know of but it all depends where you are.....
camry and aurion suffer from the same issue , where the drain tubes fall off the sunroof unit. There are 4 drains , 1 on each corner and the fix is to refit and put clamps on them this time(yes you have to drop the roof lining to access these drain tubes) i can't be definite on the avalon as i never have had one apart but i would be certain there wouldn't be too much of a difference
Thanks everyone for your replies.
I found 2 drain holes on the front side of the sunroof.
I got a 3 metre legnth of fairly stiff coax cable and
managed to shove it down for about 1.5+ metres.
I then poured some water downw each hole and had someone look under the front wheels.
The water certainly drained out.
But the roof is still leaking - but not as bad.
If there are holes on the back of the sunroof - I can't locate them.
Might have to take to Toyota.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
