Just found this place in my endless search of the interwebs for ever thing related to 3rzfe engines!
I own a 03 hilux thats some what been modified . Its a 2wd model and some may call in a "mini truck" but thats were it all stops.
Ive done a fair bit of work to the engine. Running a gt3582r garret turbo with external wastegate full 3inch exhaust from turbo back, 550cc injectors, fully forged engines with lager valves and adjustable cams, removed balance shafts, Massive port on both intake and exhaust, adpatonic ecu, and should be good for 20psi. I also have a set of track bars made up for me from a guy in the states, Have a set of sway bars coming for front and rear to stop the thing from tipping over.
Before the forged internals and top end parts on stock bottom end it rand 240rkw at the wheels on 18psi............... until i bent number 3 rod and piston slapped the crank and bent that 4tho. Whoops. Dome boost spike fairy got me
Just need a re tune hopefully next week
Yes it was scary to drive before i done the rebuild so god only knows whats its gonna be like to drive now
      Turboed Corolla Overbuilt?
    2. 3
    3. 3
    4. 0
    5. 6
    6. 18
    7. 5
      Tow bar
    9. 3
    10. 0
