Just fitted in 4 new NGK Iridium plugs having paid $14 a piece. Definitely more power and consistent engine performance. I was initially doubtful whether it will bring about any benefits but having done so, I am pleased with the outcome.
Unless your old plugs were really fouled, then I can bet that the 'more power' that you could feel is more than likely something called the placebo effect.
But it makes a difference!!!!
@ Daryl - You are on a rampage tonight!!!! hahahahahah
It is the placebo effect, Iridium spark plugs are not bought for the sole purpose of performance gains.
Chances are your sparks needed a change and you're just noticing the difference between a standard plug that is old and a newer plug that is designed to be more efficient (though technically you shouldn't be using a single electrode plug!)
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
