Just taken delivery of a Ateva 2002 and the drivers power window is acting up. It won't close automatically all the way to the top then stop. It gets to the top and then opens again, stopping halfway. It's weird. I've never owned a car with power windows so i'm not sure what's going on...
Cheers
Nick
have to take the door card off
could be a faulty switch or
the gears on the motor drive are slipping or striped or
out of alignment when stopping at the top
Someone at work who has the same model remembers reading in their owners manual that there's a safety feature on the drivers door that makes the window do this. So my question is now can this be switched off? Or reset somehow?
Jam protection is kicking in...
Check the window seal and make sure it's not kinked or ill fitting anywhere... Also, does it have a weathershield??? Clips could be making the seal stick out too far...
Once you've made sure the seal is sitting in correctly, you have to remove and seperate the motor and regulator, wind the motor up and back down then half way... Connect everything back up and should work fine...
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
