Hi gang, anyone know if these can be adjusted? On side is definatly higher than the other.
Any idea how? I am a bit worried about breaking the covers, as I did not install these. Had an auto electrician do it?
Thank you.
Take off the plastic trim from under the engine bay. From there, you can then access the foglights where you will see a knob which you can turn to adjust the aim.
Edit: I managed to fish this photo up. You will get the idea.
Just a note. You do not need to take of the plastic splash gaurd, There are holis in it that lin up with the adjuster and a phillips head screwdiver will do the trick as inside the "knob" is a screw.
Thanks gang all adjusted now but on still seems brighter than the other, perhaps a dud bulb.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
