Leaky AE92
dannyboy86
Hi there, Pick up a ae92 for $300 with original 143,000km on the clock. Ive had it for a few weeks now and i have plans on re-spraying it. Dings and dents have been fixed and I have gutted the entire car out...interior, plastic panels and carpet. The car has been outdoors and just with the on and off rain for the past 2 days I have noticed that both passenger and driver sides on the floor pans there is about half a cup to a cup of water sitting there.
Has this ever happened to anyone or know where its coming from? If so how do I go about fixing it?
When it rains, sit in the car and follow the trail.
Get new doors seals? From Toyota Parts or find some used but ok condition ones at the wreckers???
yep it will happen to all AE92's eventually just like the vents on top of the dash which all cracked right next to the join :lol:
It depends where it's parked and if leaning and that's where the water will run,hard to pinpoint but remove the strip around the windscreen (top) and you will see a few rust spots,then try locate the hole..
Careful of the strip,might need to source another if your too rough,brittle with age..
Got in it today and searched today and it seems like it was dripping on the drivers side somewhere above the fuses on the kick panel.
Plus the drain holes in the doors and the drain channel on the pillars above the door blocked so cleared them out with some wire.
Yeah the seal around the windscreen looks a bit dodge so its most probably the problem.
Ive also got the crack in the vent on the dash your talking about. :P must be a given.
      Brake issues
    2. 1
      Brake issues
    3. 1
      Hi, I'm Magazi in NSW I'm a new member
    4. 2
      Muffler change for zr6
    5. 2
    6. 26
    7. 7
      which engine oil
      G’day from NSW
    9. 3
