NOOB QUESTIONS... TO DO WITH SERVICING
mr_rice
Hey all,
Just some noob questions about when to service certain parts of my car?
COROLLA SPORTIVO 2005... bought about 6 months ago and i've only changed oil+oil filter+plugs.. (log books look like bull**** btw)
I know the obvioius ones... and what the log book says but i wanna know when everyone else does/doesn't change .. Cheers
Coolant (i mean complete flush)..... ??kms
Brake fluid (complete flush.. if that's possible/necessary) ??...kms
Gearbox oil (change)?... kms
power steering fluid (complete flush.. if that's possible/necessary) ??...kms
thanks... just worried cos a few mechanics have their own opinions... Cheers..
Rice
Edited by mr_rice
Hey all,
Rice
how many kilometres has it done? i'd just do the whole lot including the in tank fuel filter and the air filter as well.
coolant u can do every 2 to 3 years
brake fluid every year (ask mechanic to test the moisture levels: if more than 3% should completely change it)
gearbox oil: every 50,000kms
PS fluid: 100,000kms
yeah just do it all and then reset the ecu so it can learn all the new fluid and oils and filters in the car. and start counting from there.
sweet,
just to add another question but is there a diy of how to change powers steering fluid? cos last time i done it in my commodore i kept getting a noise form the pump (may have been air in the lines).
and how would i go about resetting the ecu? just undo the battery for a while or unplug the ecu itself?
thanks
Edited by mr_rice
disconnect -ve terminal of battery
pump brakes til hard
reconnect the battery
start and let it run for at least 7 mins with all accessories off
turn off engine
disconnect -ve battery again for 30 seconds
reconnect and drive
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
