2005 jdm ecu pinout (2zz)
Hi guys,
I need to locate the following pins on a 2005 jdm ecu for a 2zz.
Ignition/power (this one should not be hard)
Rpm signal +
Rpm signal -
Vvti signal
A/F Signal
Hoping someone has a pinout diagram or a way of identifing them, I have found various diagrams on the web all different tho :(
go to Apexi's japanese website and download the installation manual for a SAFC or simlar electronic device. It will have the pinouts in the manual. Same with the greddy emanage ultimate manual.
Hi guys,
Rpm signal +
Rpm signal -
Vvti signal
A/F Signal
Xoom posted an ECU pinout a few years back, its floating around somewhere on here. I think its also got an excel document attached to it which shows where everything is.
Cheers guys,
Yeah I've got that excel document but I seen so many different pinouts for different years and models I don't know what one to use haha.
Thats a good idea to use the Japanese apexi site will try that!
Yip I'm hoping to install a camcon :)
Installed it running neutral settings for now until I can get it tuned.
Also need to drill a hole in one of the center console pockets to hide it away. Will post Pictures when perfected.
did the wiring end up matching this
Took me a moment to work out this diagram, but all the pins I required matched up perfectly - good chance all the others are right too
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
