02 Auto Slipping??
Gab
hi, recently our rav has a slight slip through its gears. Wouldnt happen all the time but every 2nd time
It has 83k km and is driven by a older women from new
Its had all its services, the gear box fluid is full and still red
Not sure if its related to the other ecu topics
Would a gearbox fuid help?
any problems that can relate to this?
thnaks
You need to buy the new ecu or it'll get worse to the point of no drive at all and full transmission will also be required.
By the way, has it always been serviced by Toyota? If it has and you have log books to prove, Toyota warranty should apply.
Edited by K_wow
thnaks
How bad is the slipping? Assuming it has the right fluid it fits the typical ecu fault
      Transmission U660e
    2. 1
    3. 4
    4. 7
    5. 1
      New Guy....
    6. 0
      Gauge Pillar JZX100
    7. 0
      JZX100 CHASER A Pillar gauge pod
    8. 23
      Transmission U660e
    9. 1
    10. 1
      Toyota camry 1995
