Hi All Have Backing Sensor problems. Back to Dealer 5 times. They have given up. Any suggestions.
Posted (edited)
I'm guessing they are no go? Fuse, wiring, or sonar sensor ECU.
A detailed description of the fault helps diagnosis. :mellow:
I'm guessing a wiring issue, based on the general reliability of Nippondenso electronics.
Probably not a fuse because there are no reports or other stuff not working.
Are all the connectors ie plug & sockets firmly pushed home?
I don't have a wiring diagram for a Prado, only Tarago and Previa.
If you have or had a rear step with the side upstands the reversing sonar may have been de-programmed.
Was it working ? Did it stop? Driving in water?
Edited by robmac1
      Gearbox issue
    2. 0
      Timing Belt light
    3. 1
      Broken wiring --location help
    4. 1
    5. 1
    6. 1
      Corrolla Station wagon
    7. 1
    8. 4
      fuel door spring
    9. 2
      1999 Vienta V6 won't start
    10. 2
