Hey guys.......i just wanna know where can i get a good set of axle back exhaust? One of my friend told me that GReddy is a good brand. The reason why im after a axle one is because i dont wanna void my warranty.
googled it ,
if you are after a bolt on set, there isnt any. your car is fairly new so there is limited aftermarket things.
however i have found lowering springs if you are interested.
http://www.meganracingperformance.com/12_13_toyota_camry_parts_catalog_vm.html
you best chance, head straight to an exhaust place ask them questions and all that.
I doubt there will be any aftermarket stuff until warranty runs out - im sure 99% if not 100% of people here dont want to void their warrnty :)
I think you should be able to yes, as long as a liscensed person does it.
It may depending what you're replacing I think, if you're just replacing pipes it should be ok, but if there's welding involved etc it may be noticed at your next service if they lift your car.
If it was up to me I'd wait till warranty was over :)
I have no idea how a change of the mufflers will cause warranty issues. It's not as though more noise and flow will cause the car to implode.
i think it will void your warranty and not just on that part of the car, it may also affect your emissions.
      Broken wiring --location help
    2. 1
    3. 1
    4. 1
      Corrolla Station wagon
    5. 1
    6. 4
      fuel door spring
    7. 2
      1999 Vienta V6 won't start
    8. 2
    9. 4
      fuel door spring
    10. 2
